IGBT gate driver
Discussion in 'General Electronics Chat' started by dhakal50, Jun 28, 2011.
  1. dhakal50
    Jun 28, 2011
    5
    I am using a IGBT gate driver IR2117 to drive a IGBT which drives a 4- quadrant PMDC motor of 75 V dc. I have a problem with driver. The input to the driver is PWM technique. The problem is the IGBT driver chip always blows out when I switch on the dc supply. Actually if the duty cycle is 50% then it is fine but when the duty cycle is increased to 95% it always blows out. Sometimes IGBT too.
    Any help will be appreciated from my heart.
  2. shortbus
    Sep 30, 2009
    4,096
    1,692
  3. nigelwright7557
    May 10, 2008
    488
    71
    Could be bus pumping forcing up the power supply volts ?
    Watch the power supply when you power up and see if it pumps up way above normal voltage on 95% duty cycle.
  4. dhakal50
    Jun 28, 2011
    5
    No the voltage remain in the normal condition.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Do you have a schematic?
    Turning ON the DC Power supply, you mean you turn on the bus voltage and the controller is already working, or you first apply the bus voltage and then turn on the controller voltage? (Even if you turn them on at the same time there will be a delay, what's that delay?)
    To avoid burning and do some tests you could lower your bus voltage until you find out what's going on.
    What IGBT are you using?
  6. dhakal50
    Jun 28, 2011
    5
    Ya I have schematics. At first I turn on the control circuit and only I turn On the DC Bus. There is sufficient time delay between these two turn on. By lowering the DC bus voltage sometimes the IGBT driver doesn't blow out. The motor I am using is a 75 V dc and it draws 5.8 amps at full load. The IGBT I am using is G4PC40FD.
    • Lab7.pdf
      File size:
      93.6 KB
      112
  7. praondevou
    Jul 9, 2011
    2,936
    489
    Q1 and Q4 don't have an emitter connection to their drivers? Or is it just not drawn?
    Did you measure your deadtime?
    Are you sure that the outputs of the opamps and therefore the output of the 2117s are OFF at the moment (and shortly after) you turn on DC?
  8. praondevou
    Jul 9, 2011
    2,936
    489
    Which IGBT burns? Looks like cross conduction.
  9. dhakal50
    Jun 28, 2011
    5
    The emitter of Q1 and Q4 is not drawn. Sorry about that. My dead time is about 600 ns. I usually turn on the drive circuit then only turn on the DC bus. I don't know whether I have to turn on DC bus first then turn on the driver circuit or do it in opposite way. Usually my Chip IR2117 blows out not the IGBT.
  10. praondevou
    Jul 9, 2011
    2,936
    489
    No , the way u do it is better, first control side, then power side.
    As the failure seem to originate from the driver and not the IGBT, can you put less bus voltage on your circuit and see if you have a negative voltage spike at your driver output at the moment the output signal goes from High to Low? If yes, how big is it?
    600ns is bigger than the turn-off time of the IGBT but can you increase it a bit? Just to make sure.
    What's the distance from driver to IGBT?
    For testing purposes you can also take the load out of your circuit and put a light bulb in series with your bus voltage, if cross-conduction occurs at least the IGBT won't blow.
    dhakal50 likes this.
  11. dhakal50
    Jun 28, 2011
    5
    Finally I changed my Cap values and it stopped blowing. Thanks for your help.
  12. praondevou
    Jul 9, 2011
    2,936
    489
    Hi, if possible I would like to know what cap values you changed. Power circuit, control circuit, deadtime?
