Does the rectified voltage have the same ground as the other part of the circuit?
Also, try to connect the load between the drain and the 15V supply and see if it chops it.
For the circuit to work properly you need to connect the ground of the rectified voltage to the ground of the other circuit. Also, you get a sawtooth wave because the MOS turns on slow. You will need to put a BJT after the 555 to decrease the turn on time. Also, replace the 10K resistor with a 1K to decrease the turn off time. Also, disconnect the load from the rectified voltage and connect it to the 15V and observe the waveform.
Ok that's good. I thought this about ground from the beginning but on your diagrams you had grounds to both supplies and I assumed that they are connected in reality too. The buzz is usually due to loose windings or a loose piece of metal on the variac or near it. How does the waveform looks like?
the wave form looks like a series of straight up spikes
that climb from base to a peak and start to decend after the peak
the center base line voltage also rises a little
the buzzing is decently loud sounds amost like when it is direct sort it but not quite as loud it dosent make this sound when its connected directly with out pulsing
what do i need to setup a bjt
the irfp450 gets hot real quick
thanks alot mik3 this was driving me nuts for a while
Disconnect the 10 ohm resistor from the 555, connect the emitter of the BJT to the 10 ohm resistor, its base to 555 and its collector to 15V. If you want decrease the 1K resistor to 500 ohm to decrease the turn off time.
You place a diode in parallel with the load but I don't if you can do it in your case because you want to make something to resonate. Another solution is to put a transient suppressor in parallel with the IGBT with a break down voltage less than the IGBT can withstand.
could i use a transient suppresion diode or maybe an isolation transformer
also if you look at the last wave form i posted using the igbt the waves are just straight up peaks their is no width to them can i widen the width up by changing the resistor from collector to gate to a higher resistance or is this pretty much how an igbt works
thank alot mik3 for your help i really appreciate it
