IGBT - Fuji Electric
Discussion in 'General Electronics Chat' started by copucopu, Jan 5, 2015.
  1. copucopu
    May 26, 2014
    21
  2. praondevou
    Jul 9, 2011
    2,936
    489
    It looks like the current rating is for each IGBT.
    Since you will be driving the IGBTs with PWM you should just make sure to not exceed the pulse collector current rating. It has built-in overtemperature protection.
    The motor power rating will give you the maximum the motor should be subjected to, under varying load conditions the current through the IGBT will vary as well.
    The motor will also draw more current when started.
  3. copucopu
    May 26, 2014
    21
    Is there anyway to be shure regarding the current in phases?
    How can I define from the datasheet what is the max power which can this IGBT handle?
    Thank you.
  4. copucopu
    May 26, 2014
    21
    Anyone?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    the max power each can handle is in the data sheet, along with max current and voltae..
