IGBT and MOSFET
Discussion in 'General Electronics Chat' started by Surendar, Feb 14, 2006.
  1. Surendar
    Sep 12, 2005
    18
    Could anyone explain the differences between IGBT and MOSFET.
    Thank You
    Surendar
  2. n9xv
    Jan 18, 2005
    329
    IGBT stands for Isolated Gate Bipoar Transistor. Its a bipolar transistor with an isolated gate for the control input. In other words its a voltage controlled bipolar transistor. Whereas bipolar transistors are normally current controlled. With IGBTs, a simple input (low level voltage, logic level etc) can be used to controll extreemly large amounts of current. You find IGBTs in large motor controll and switching supply applications. MOSFETs can perform similar tasks but at the higher currents as IGBTs. MOSFETs are more common in RF power devices where a much higher switching speed is necessary. In really high current applications, the IGBTs can be as big as a brick!
    USComponent likes this.
