Sure, there's a few places to have your own design rolled if you have a deep bankroll.Would hobbyist be interested in custom silicon chips?
FPGA's don't care about that.does not have to be synchronous
http://www.mouser.com/ProductDetail/Atmel/ATF750LVC-15SU/?qs=b1J4i6otjZuGI1NPYNxERg==&gclid=CjwKEAjws7OwBRCn2Ome5tPP8gESJAAfopWsGT6Ga0xb-OR147iDccXjA44jvEW-wvk7Xhw2wQMx3RoCXx7w_wcB&kpid=55894416Personally if I had the choice of either an FPGA in a BGA package or TSOP against a custom silicon chip in DIP or SOIC I would go silicon hands down.
The why didn't you?10 Macrocells, great...
I designed and created (fully working), composite video graphics card that needed two Xilinx 95XL72 CPLDs in PLCC packaging (total of 144 macrocells). And even then I needed external IO control via 7400 chips. It would have been great to have the whole thing on a single chip
You can do all that with FPGA's too. It's a matter of secifying constraints.FPGAs and CPLD both do not care about design being sync/ async BUT you have race condittions and because you do not know how the routing is done you cannot time your signals (hence why async is not advised in FPGA design). In silicon you can carefully trim and design your metal layers so that signals arrive before other signals do. For example, pulse creation on a flip flop clock or latched device is done using carefully designed silicon.
That was the point I was trying to make. Unless you're a well-funded manufacturer, programmable devices are the way to go. They aren't perfect; slower, less dense, etc. But for homebrew, they are just about the only viable choice.I cant have the whole design on a single chip because I cant afford to get a chip fabricated. ... Plus if there is a mistake then you need to get an other PCB which is pricey.
That's pretty much the path for all digital design going forward.[/QUOTE][/QUOTE]I know that you can specify constraints but every tutorial, lesson or advice from senior engineers who have experience in FPGA design all agree that async designs are bad and must be avoided.
Steve Sanghi - CEO
Well, let me comment on the utilization. First of all, the Gresham factory in Oregon is a newer factory and in a newer factory we need a -- once in a five years we need a major shutdown to repair things that can't be repaired while the factory is running. And that shut down has been previously scheduled for a year for this October and that shutdown usually is about seven to eight days you have to shut the factory and we reserve for it going into that shutdown, and it's planned shutdown, we have to do it every once in a five years.
by Aaron Carman
by Aaron Carman
by Duane Benson
