If you need MatLab help, plz message
Discussion in 'Programmer's Corner' started by Brandon, Dec 30, 2004.
  1. Brandon
    Thread Starter Senior Member
    Dec 14, 2004
    306
    I have a lot of experience with MatLab in a handfull of areas and if anyone runs into some issues, please be sure to post or message me.
    I'll be glad to help.
  2. braddy
    Dec 29, 2004
    83
    Hey Brandon,
    I am happy to hear that. I have another exercice. Me too, I would like to have as good as you on Matlab.
    This is another problem:
    Suppose that the function file bounds.m and the script file main.m as indicated below are in the current directory. If main.m is "run", what would you expect to see in the command window?
    main.m
    clear;
    x=[1:.1:2];
    n=5;
    [xl,xu]=bounds(2.9);
    disp('lower upper');
    disp([xl,xu]);
    z=[3.5,-1.4,8.9];
    [zl,zu]=bounds(z);
    disp([zl',zu']);
    disp(n);
    a=[4.2,-1.1;3.7,-6.3];
    [al,au]=bounds(a);
    disp([al,au]);
    disp(n);
    Here is the function bounds that is used in solve main.m:
    bounds.m
    function [beneath,above] = bounds(x)
    %function to find glb and lub for x
    [n,m]=size(x);
    if (n>1)&(m>1)
    error('Function not valid for
    2-D arrays');
    else
    above=ceil(x);
    beneath=floor(x);
    end
    Do you have an personal email?
    B.
  3. Brandon
    Dec 14, 2004
    306
    Alright, the bounds.m function generates 2 arrays representing the intenger boundaries from a single input array.
    [xl,xu]=bounds(2.9); would give us
    xl=2 xu=3
    [2 3]
    z=[3.5,-1.4,8.9];
    You should see something like this on the screen
    lower upper
    2 3
    3 4
    -2 -1
    8 9
    5
    Function not valid for 2-D array
    0 0
    5
    or something very very similar to this.
