If we multiply each side of a triangle by two, the angles inside the triangle will?
Discussion in 'Homework Help' started by masterqtkd, Apr 20, 2015.
  1. masterqtkd
    Apr 20, 2015
    1-double
    2-halves
    3-reduce by √2
    4-not change
    Kind of confused, haven't do this since high school. lol
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    What have you done so far?
    Hint: Consider a triangle with sides of 1,2,3. Does it matter what units are used for those measures?
    John
  3. masterqtkd
    Apr 20, 2015
    no it won't matter, is just a question in a text book.. :)
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    You have just answered your own question.
    John
  5. masterqtkd
    Apr 20, 2015
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    Now, the next part of learning is to try teaching. So, can you explain why it doesn't matter?
    John
  7. tjohnson
    Dec 23, 2014
    618
    122
    Assuming that the units stay the same (which seems highly probable to me), it's not difficult to figure out the answer to your question. Just draw two simple triangles (like 45-45-90 ones), one with sides of length x and another with sides of length 2x, and then measure the angles with a protractor.
    Note: I know what the correct answer is, but it would be unethical for me to give it away.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    I don't think it is a good idea to try to prove something using an example that might well be a special case. The proof should apply to any triangle.
    If you have studied lines intersecting parallel lines, you might find those properties useful here.
    I am assuming this a geometry class, not trigonometry, right?
    John
  9. tjohnson
    Dec 23, 2014
    618
    122
    I just mentioned 45-45-90 triangles as an example because they might be simpler to draw, but any triangle will work.
    @jpanhalt: Are you saying that you think a 45-45-90 triangle would be a special case? I didn't think it would for this proof, but maybe I'm misunderstanding the OP.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    The point is that if you choose fifteen triangles and show that it works for those fifteen triangles, you haven't proven that it will work for anything other than those fifteen triangles. You may have made a very strong case that it probably would work for all triangles, but you haven't "proven" anything.
  11. tjohnson
    Dec 23, 2014
    618
    122
    Right. I wasn't recommending a way to make a proof, since I didn't think that's what the OP was talking about. I was assuming that he just wants to find the answer to an individual problem, but it would be an excellent idea to research the reasoning behind the proof as well.
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
  13. MrAl
    Distinguished Member
    Jun 17, 2014
    2,553
    515
    Yeah, like linear magnification. If you look at a triangle through a telescope it still looks the same.
    Trigonometry has a lot to do with ratios rather than absolute values.
