if we have a x we also have a x prime
Discussion in 'General Electronics Chat' started by hamdi, Oct 29, 2005.
  1. hamdi
    Oct 29, 2005
    i cannot understand
    if we have a input signal such as X
    we dont need to use inverter in the first input of the gates
    can you explain why ?
  2. Overclocked2300
    Apr 24, 2005
    124
    X prime is just an inverted state of X, also called X not.
    You dont need an inverter because the signal is inverted INSIDE the chip, rather than using an external chip.
  3. hamdi
    Oct 29, 2005
    Thanks but I didnt really understand. can you explain how to we do it.
  4. Overclocked2300
    Apr 24, 2005
    124
    Inside the IC, there is an inverter. It takes the input X and flips it to X not (also called X` or X prime) Prime just indicates its the opposite.
    Example: If X=1, then X`=0. If X=0, then X`=1.
