I actually have three related questions:
An open circuit chemical cell separates charges creating a surplus of electrons on its negative terminus and a shortage of electrons on its positive terminus. The separation of charges is conducted by chemical reactions. As electrons accumulate on the negative electrode, they repulse each other, so it takes more work to put any additional electrons in the negative electrode, so eventually, after a certain potential difference is achieved, the chemical reactions are inhibited and stopped.
1) If we connect a long wire to the negative terminus, the accumulated electrons will evenly distribute themselves along the wire, because of their mutual repulsion. Thus, the charge density at the negative electrode will decrease. Will this cause the battery to relaunch the chemical reactions and put more electrons in the negative electrode?
Let's say we connected two long wires to a chemical cell, one to it's negative electrode, another to it's positive electrode (the wires do not connect to each other). The negative wire will thus acquire some extra electrons, the positive wire will have a shortage of electrons.
2) If now we disconnect the wires from the battery, will they remain charged? And how is this charge mathematically related to the emf of the battery?
If we connect the wires to the battery as described above, the potential difference between their termini will be about the same as the emf of the battery.
3) If we disconnect the wires from the battery and they remain charged, what will be the potential difference between the wires?
Thank you.
Thank you.
