I was trying to see if using a higher current in a flash circuit would make the cap charge faster and yield shorter wait times between flashes (for photography purposes) but I haven't seen any data on a capacitors maximum input current.
Is there a way to find the max current that can be input to a given capacitor? I haven't seen that info anywhere.Yes, it will charge faster, and yes, you have to stay within specifications. A moder cap with low ESR can help get to high current.
??? You don't force more current into the capacitor. A lower resistor value allows more current, charging faster. T = R x C. "I" isn't in the equation. Yes, a capacitor with a lower ESR will help, but not a lot.Is there a way to find the max current that can be input to a given capacitor? I haven't seen that info anywhere.
Is it being recharged from a battery or a main power source?I was trying to see if using a higher current in a flash circuit would make the cap charge faster and yield shorter wait times between flashes (for photography purposes) but I haven't seen any data on a capacitors maximum input current.
You want to charge at twice the current cut the resistance in half.Yeah that was my thought actually. Just to use a slightly more powerful transformer that would output a higher current. I'm not sure if a higher voltage would do anything more amps is what I was wondering about. That's why I was asking how much a capacitor can typically handle since I don't want to do 2 amps instead of 1 and end up with little bits of shrapnel in my head.
If it can put out several tens of amps in a short pulse it can obviously handle that going back in.Yeah that was my thought actually. Just to use a slightly more powerful transformer that would output a higher current. I'm not sure if a higher voltage would do anything more amps is what I was wondering about. That's why I was asking how much a capacitor can typically handle since I don't want to do 2 amps instead of 1 and end up with little bits of shrapnel in my head.
by Duane Benson
by Aaron Carman
