IEC standard resistors for LTSpice
Discussion in 'Analog & Mixed-Signal Design' started by mitchthetitch, Oct 12, 2016.
  1. mitchthetitch
    Mar 29, 2013
    I have just downloaded LTspice to do a piece of work and have just realised that the resistor symbols aren't IEC standard ( the box ones) and are the american ones. Is there anyway to get the english ones instead??
  2. kubeek
    Sep 20, 2005
    4,689
    806
    No easy way that I know of, but what you can do is edit the LTspiceIV/lib/sym/res.asy symbol to look the way you want - draw new lines, delet the olde ones. However I think that any schematic you make and send to someone else will revert back to US style resistors unless they change that file as well.
  3. Alec_t
    Sep 17, 2013
    5,979
    1,138
    If you look in the Misc folder you will see 'European Resistor'.
