IEC DC Color Codes
Discussion in 'General Electronics Chat' started by Phil_TX, May 14, 2008.
  1. Phil_TX
    May 14, 2008
    Hi everyone, I'm a newby here and found site has tons of knowledge available and I would like to tap some of that knowledge with a few questions on IEC color codes.
    Here's the situation: I am presently working on an oil production project in Russia. The project specs state that all wiring insulation colors are to follow IEC 60446. I pull this spec up and it only addresses AC circuits and states that DC circuit colors are not defined. Now that I have found this site I see the wiring color code page and it does identify the colors for DC wiring. The tables on this page state that the colors are per IEC, but doesn't state what IEC standard. Can someone tell me what IEC standard these color codes came from..?
    Other quesions I have regarding DC wiring color codes are:
    Does the IEC state wire colors for different voltage levels of DC voltage. For example, what would the colors be for these voltage levels:
    125VDC
    48VDC
    24VDC
    12VDC
    I'll admit that the issue of wire colors as stated in the IEC are a bit confusing to me. Is there actually an IEC standard that dictates colors for the voltage levels I have listed or are these colors left up to some other authority..?
    Thanks for any feedback.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hey Phil,
    Welcome to the forum!
    Sorry, I have no idea what the answer to your question is - but I didn't want you to feel ignored either ;)
    Where are ya in Russia? It's like a whole 'nuther country, ain't it? ;)
  3. loosewire
    Apr 25, 2008
    1,584
    435
    Phil,Texas -Go wikipedia search-FUSE Electrical I think I saw all the color and
    voltage's you are asking about. Are you(( REAL TEXAS LIKE BILL)) I do fire ant research and Texas is my place to bunk out and teach.DAVE if you move this off topic please advise,Phil. Thank's again as alway's
