Iec Cp22s
Discussion in 'General Electronics Chat' started by nbaptista, Aug 30, 2014.
  1. nbaptista
    Aug 21, 2014
    27
    I have an IEC cp22s that only accepts 3*1 mm2 conductors. I want to solder a cable with 3*1,5 mm2 conductors. Is there any problema of mecanical stress due the larger diameter of the conductors?I´m doing a power cord or a mains lead!
    http://www.cliffuk.co.uk/products/inlets/ms1.htm
    You can see the IEC at the end of the site!
  2. #12
    Nov 30, 2010
    16,704
    7,354
    Miserable PDF on that page. Can't read the sizes.
    1MM dia is less than 18 gauge American. I certainly hope you can fit a larger wire on those terminals!
  3. nbaptista
    Aug 21, 2014
    27
    Why do you think so?I have read that these terminals only accept 3*1,0 mm2, but was on an Internet site, so I´m not sure!
  4. #12
    Nov 30, 2010
    16,704
    7,354
    mm squared? Maybe I interpreted that wrong.
    math math math...
    I'm getting cr@p out of my calculator.
    Maybe it's the drugs...:D
    (Recently out of hospital. Promised not to do math on the website this week.)
  5. nbaptista
    Aug 21, 2014
    27
  6. #12
    Nov 30, 2010
    16,704
    7,354
    Somebody, help me out here!
    I've lost my math brains for a while.
  7. b1u3sf4n09
    Member
    May 23, 2014
    115
    14
    "CLIFF CP22S 3 pole appliance plug. Rewirable. Rated 10A 250VAC.
    Cable connections can be made by soldering or by screws.
    Max cable 3 x 1.0mm2. Fits MS-1 and MS-3 inlets."
    From that description, I'm not sure if the size limit is due to the cable entry or the screw terminals. If you are able to terminate the cable ends and still close the connector housing, I think you should be fine.
  8. ISB123
    May 21, 2014
    1,240
    531
    Why would they require 1 mm wire which can pass 2,3A max. and rate the switch for 10A?
  9. #12
    Nov 30, 2010
    16,704
    7,354
    That's what I was barking at, but I can't prove it with math right now.
  10. nbaptista
    Aug 21, 2014
    27
  11. #12
    Nov 30, 2010
    16,704
    7,354
    1.5 times the area of the cross section should flow 1.5 times 2.3 amps. Right?
  12. nbaptista
    Aug 21, 2014
    27
    1 mm wire can pass 2,3 A Max,? How did you do the calculus?
  13. #12
    Nov 30, 2010
    16,704
    7,354
    More likely it was a look-up table. The current limit for wire is often about the quality of the insulation. Some wire is rated for 60C, some for 75C and some for 125C. Your casual power cord and hook-up wires are usually rated for fairly low temperatures.
  14. ISB123
    May 21, 2014
    1,240
    531
    OK it seems that we didn't read the datasheet properly ;).
    Basically it says that it includes 3 x 1mm wires that are sticking out so you can solder them :D.
  15. nbaptista
    Aug 21, 2014
    27
    And soldering the IEC doesn´t have the problema to break with time?It is a rigid connection...
  16. ISB123
    May 21, 2014
    1,240
    531
  17. nbaptista
    Aug 21, 2014
    27
    it is to solder the wire to the iec connector
  18. ISB123
    May 21, 2014
    1,240
    531
    Its to solder any wire.
