Idle control valve solenoid
Discussion in 'General Electronics Chat' started by Tree1, Aug 10, 2011.
  1. Tree1
    Nov 30, 2010
    46
    Typically Idle control valves are controlled by a transistor in the ECM. If you were to monitor the voltage across the solenoid, wouldn't you see some kind of voltage spike instead of a perfect pulse??
  2. debe
    Sep 21, 2010
    955
    185
    They are either controled by a steper motor or solenoid with PWM square waves. Usualy measured using duty cycle on a multimeter.
    Tree1 likes this.
