Heres hardware. And being a programmer is HARDER than being a <snip> little electronics engineer - IF! One of those <snip> could even teach anything, because they DONT understand anything! So how can they teach it??
OK! LETS GET ON WITH BATTERY LOGIC!
say i have 2 wires connected to their negative terminal to a wire each.
Then i connect these wires to another wire to a battery connected to its positive terminal.
First I notice 9v dc going through, with my voltmetre, because 2 negative terminals, connecting only to only 1 positive terminal, will only draw the same volts from both, because it only has the potential difference given by the positive terminal on the other side, but will draw it from both batteries at once, This way, I go through twice as much outputs as my inputs batteries .
Then I start disconnecting things.
If I disconnect the first battery, then I notice, I still have 9v there, because the potential difference is still there.
Then I reconnect that battery, and remove the other, and I notice its still 9v.
If I disconnect both batteries, now its 0v.
Then I conclude, this is an OR gate, just by crossing 2 wires.
I can then connect up 4 batteries on one side negative, and 2 batteries on the other side positive.
But I make sure only to connect 2 of the batteries at once, because every two batteries counts as a bit, one for 1, one for 0. 9v for 1. 9v for 0.
Now I find I can connect the 1 batteries together, cross the wire, and go to the 0 battery on the positive side.
Now ive got a NOR gate. its the opposite, because of its inverted OUTPUT.
So then I then connect the 0 batteries together, cross the wire, go to the (1) positive. and because I inverted the INPUT, I now have a NAND gate.
Then I connect the 0 batteries to the 0 positive, and ive got an AND gate, but its signifying the lack of it, but not actually having it. and thats where im up to.
The other thing im missing, is getting rid of the batteries, and then making the output feed back into the input. And then I have a differential analyzer (simple summer) and ram.
Ram is excellent in this method, because its 2 NOR's in feedback, so theres no stuffing around and its simple to think of this way.
