identifying part
Discussion in 'General Electronics Chat' started by Sparky, May 20, 2013.
  1. Sparky
    Thread Starter AAC Fanatic!
    Aug 1, 2005
    75
    Attached is an image of a part I could use some help identifying.
    It is out of a generator and was in series with a potentiometer (only 2 of the three terminals, the other was unconnected)
    I guess it is a power resistor but this is a guess.
    I do get 230'ish ohms across the outside most (dirty) terminals and 140'ish ohm between the one other set (from the lead labeled common to the lead still attached.
    Thanks,
    Sparky
  2. MMH
    Member
    Feb 8, 2013
    143
    It is not a resistor, that's for sure. What is the left most one?? Is it COM?? Looks like a multimeter pin:D
  3. gerty
    Aug 30, 2007
    1,154
    304
    That's what it looks like to me 10-20 watt.
  4. praondevou
    Jul 9, 2011
    2,936
    489
  5. Sparky
    Aug 1, 2005
    75
    MMH - yes the left most label is "COMMON", middle =
    "110 115 240" and end opposite COMMON is "120"
    Sparky
