Identifying Components/Circuit
Discussion in 'General Electronics Chat' started by Ric, Jun 19, 2010.
  1. Ric
    Jun 23, 2009
    6
    Hey there,
    Firstly I apologise if this is in the wrong section but hopefully it's not :)
    I've been trying to figure out a circuit based on images of it someone has posted online as I'd like to do something similar. Unfortunately they are not the clearest images so I haven't been able to get any details from them (IC Numbers). There is also a video showing the circuit in action so I'm very much hoping you might be able to point me in the right direction as to what components are being used.
    Video: http://s257.photobucket.com/albums/hh219/petesixteen/?action=view&current=MVI_0909.flv
    I've tried asking the author of the above but unfortunately it was done a few years ago and I am yet to get a response.
    Thanks in advance for any help.
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    I bet it's the 555 timer, perhaps.
  3. Ric
    Jun 23, 2009
    6
    I was wondering that at first, then I thought it could be an Op Amp but that means the grey component which I initially thought was a capacitor would be a tone generator or melody generator as I've seen them called.
    From my some what limited knowledge of electronics (an A-level several years ago has mostly been forgotten, sadly) if the op-amp's frequency had been adjusted to slow down the flashing LED's then wouldn't that affect the audio output too?
    Edit: I might have answered my own question here, I've just stumbled across a PICAXE-08M Chip
    I believe that might answer my question as according to: http://www.paulgardiner.dsl.pipex.com/EiSS/eiss.html?ks3and4projectpcbs.html (second one down) it can also control 2 LED's
  4. sceadwian
    Jun 1, 2009
    499
    37
    Based on the video it's definitely a micro controller of some sort. You could probably use just about any general purpose 8 pin micro controller to make a project similar. But you'd have to be able to program it.
  5. Ric
    Jun 23, 2009
    6
    I've decided to follow up with the Picaxe chip as after some reasearch it looks pretty easy to program and should be fairly easy to do what I need. Thanks again for your help.
