Identifying burnt resistors in power supply section of commercial amp using STK4192 II IC.
Discussion in 'The Projects Forum' started by Max12345, Sep 9, 2016.
  1. Max12345
    Aug 27, 2013
    63
    Greetings to all
    I have an amplifier using a STK4192II IC. It seems that a number of manufacturers have used this same IC in their amps.
    There are 2 burnt/blown resistors in the power supply section which I want to replace, but obviously their markings are no longer visible.
    I measured them out of the circuit and one was open circuit while the other read 5.3 ohms. They seem to be identical resistors (unsure) as they both appear to to follow similar paths to the chip: from power supply capacitor bank to two unmarked caps, to the resistors in question, to the fuses, to the chip via a couple of other component (caps and resistors).
    I have attached pics of the circuit board as well as pics of some (identical?) amps.
    Does anyone have a similar amp and can tell me what the values of these resistors are please? Or anyone have an idea of what they are?
    Max
  2. AlbertHall
    Jun 4, 2014
    2,259
    446
    Before replacing the resistors you need to establish the reason that they got smoked otherwise any replacements will go the same way.
    If these resistors are in series with the power feeds to the amplifier chip then a value around 4.7Ω is not unreasonable so once the main fault is fixed I would replace them with that value and see whether it works.
  3. Max12345
    Aug 27, 2013
    63
    Thank you for the reply, AlbertHall. I had assumed that the resistors had too low a power rating.
    The bodies of the resistors are 9mm and are too big for ¼W bu too small for ½W.
    Once I knew what the resistance was, I was going to increase the power rating to 1 or 2W.
    Any tips on how to go about looking for the main fault?
    Thanks, Max
  4. AlbertHall
    Jun 4, 2014
    2,259
    446
    It is unlikely it is a design fault.
    You will have to see what they are connected to, probably one of those things is shorted. Prime candidate is probably that big chip but could also be electrolytic capacitors.
  5. #12
    Nov 30, 2010
    16,664
    7,311
    In my experience, it's always been that big, fat, audio amp chip.
    No Longer Available at www.mouser.com
  6. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
  7. Max12345
    Aug 27, 2013
    63
    Thanks for the replies #12, KISS and AlbertHall.
    I have attached a pic of the circuit.
    What do you think?
    Max
  8. AlbertHall
    Jun 4, 2014
    2,259
    446
    It is most unlikely they were 2.2k resistors - 23V across 2.2K would dissipate just 0.25W, so the voltage to burn them so thoroughly just isn't there.
    Are the burnt resistors connected via 0.1uF (or some value in that region) capacitors to the speaker terminals?
    If it is those two then it seems the amplifier was producing a lot of power at high frequency - above audio frequencies. Maybe it was oscillating.
  9. Dodgydave
    Jun 22, 2012
    5,139
    767
    I would search for the manual of your amplifier, and look at the resistors R153/4 in the parts list.
  10. Max12345
    Aug 27, 2013
    63
    I think that they are the resistors across the speakers as i could trace them to the 2k2 resistors and the 47uF caps to pins 5 and 15. Dodgydave, i can't seem to find a schematic for the amp unfortunately...
  11. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
    Yep, oscillating or maybe picking up RF from a local radio station. Any radio station transmitters really close?
  12. SLK001
    Nov 29, 2011
    849
    242
    Neither fuse blew?
    BTW, you still haven't told us the make and model of your amp.
  13. Max12345
    Aug 27, 2013
    63
    KISS, no radio stations close by, but fairly close to a mountain which transmits TV signals. Why would it oscillate and how do I prevent it from occurring?
    SLK001, no neither fuse blew. The amps looks like the pics (the black one) but they all look identical except for the colour. I had to replace the knobs as there weren't any so my knobs are silver.
    The name is missing from the front cover, but essentially they are called PA-3038.
  14. Max12345
    Aug 27, 2013
    63
  15. AlbertHall
    Jun 4, 2014
    2,259
    446
    Does the amplifier still work? If it's those two resistors I would expect it to make some attempt at working. If it doesn't work at all that is probably the easiest fault to find.
  16. Max12345
    Aug 27, 2013
    63
    Yes it still works, but I don't want to blow the IC by using it often until I replace those resistors.
  17. AlbertHall
    Jun 4, 2014
    2,259
    446
    Do you have an oscilloscope that could look for oscillations?
    I would replace those resistors (perhaps buy 4 while you're at it) and see what happens. If they smoke or the 'scope sees igh frequency output, then you still have a problem that needs fixing. If the resistors survive then keep your fingers crossed...
  18. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
    http://audiosystemsgroup.com/Ferrites-Ham.pdf
    You could try a ferrite bead on the inputs. Use twisted pair for the speakers. It does not have to be shielded.
    What frequency is the TV transmitter? What are the lengths of your cables including the speaker cables?
    Problems if they are a multiple of the wavelength including 1/4, 1/2 etc. See: http://www.1728.org/freqwave.htm
    Changing the lengths could help.
    I'd probably start with twisted pair speaker cables. A variable speed drill can twist wires nicely.
    Even making your audio cables out of twisted pair could help.
    A typical example: http://www.bellscb.com/products/accessories/RF_Choke_Snap-On_Large_FRCK.htm
  19. Max12345
    Aug 27, 2013
    63
    AlbertHall I have replaced the resistors with 4R7 2 W ones but havent switched on yet. KISS thanx for all the info. I amm going to go thru that at my leisure. The transmiitters transmit on VHF. For now I am going to do the twisted pair speaker wires. They are about 3m long Thanx guys
