Identify this circuit board:
Discussion in 'General Electronics Chat' started by Razor Concepts, Dec 16, 2009.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    It can be different things, like a data filter / converter, a progamming device.
    There are two connectors.
    What are the connector types?
    It contains a PIC16C54 o/p.
    This is a programmable chip that can perform different tasks.
    The task performed is dependend on the program in the PIC.
    The problem is that you probably do not know what is programmed.
    Greetings,
    Bertus
  3. ke5nnt
    Mar 1, 2009
    384
    15
    The second DIP chip is a buffer amplifier. The top-down view is nice for reading component labels, but impossible for seeing any depth to anything. It would be nice to be able to see what those connectors look like. Are they USB?
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    @ke5nnt.
    You are right, from the WIKI:
    • 74125: Quad Bus Buffer with Three-State Outputs, Negative Enable
    Greetings,
    Bertus
