Identify Capacitor?
Discussion in 'General Electronics Chat' started by jklcircuits, Feb 23, 2009.
  1. jklcircuits
    Feb 23, 2009
    This is on a 20 year old automotive circuit board I would like to try to fix. Can anyone identify the part or a functionally equivalent replacement?
    Markings are:
    33+
    10P
    [m]
    Any help would be appreciated.
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    That's a 33 uF tantalum capacitor.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  4. jklcircuits
    Feb 23, 2009
    Thanks for the replies. Since both the 33 and 10 were common numbers I wasn't sure which was for μF and which for Volts. Thanks for clearing that up. You can probably tell by that that I am a novice.
    Since neither of you mentioned the tolerance indicator 'P' can I assume that that value is less relevant when it comes to finding a replacement? In my brief online searches so far I haven't found anything with the same tolerance ratings. P = +100% ,-0%
    Cheers,
    John
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Any capacitor of 33 μF with a voltage higher or equal to 10 Volts will work.
    (do mind the + sign, placing it the wrong way around can blow it).
    Greetings,
    Bertus
