Hey guys, my space heater won't turn on and I found the problem (when I do get it to run, it runs perfectly). It seems to be the main push button switch (you can see below between the 2 green capacitors). It has four terminals and you push it multiple times to cycle through temp settings and so forth.
Can any of you tell me what kind of switch this is so I can find one to replace it? I searched a little bit but there are so many out there and I figured some of you very experienced guys might know. Thanks a lot!
(If you need a clearer picture, let me know)
