Hi all. I need some help identifying a capacitor. Its out of a Crest Audio HP-8/32 Mixing Console. It is a surface mount Aluminum can capacitor, with 3 lines of markings. The first is '[a square symbol] 4U', then the second line is '47', and the third line is '35v'. I figured it was a 47uF capacitor rated at 35 volts. So i bought some, but they are larger, slightly (but enough so they cover the PCB's contacts). The capacitors i bought are Rubycon, marked 'UIC' 47 35v. Any idea what the [Square symbol] 4U means, and where i can find this online? Thanks.
