Hi all, I am putting together a project which has 4 LED strips and a Push button switch which I am connecting to a 12v Car Battery. Only problem is the resistance of the switch is absolutely killing the brightness of the LED's. I thought by wiring the circuit in parallel instead of series I might be able to retain the brightness more. Firstly, is this accurate thinking? Secondly the switch is an 8pin DPDT Backlit Metal switch and I cannot work out how to wire it in parallel to the Battery and LED's. Any ideas? Pictures of the switch and pins below.
