OK... I entered the program with just the two lines as you indicated in your last post.
Now I have 0 volts on the ULN2803 pins 1-8
I still have 17-18 volts on ULN2803 pins 12-18 with positive lead on +24vdc.
Now I have 0.47 volt on pins 12-14 of ULN2803 and 1.47 volts on pins 15-18 with the positive
meter lead on +5vdc.
Also measuring between ground and the ULN2803 pins 12-14 I have 3.9 vdc and on pins
15-18 I have 1.29 vdc.
Seems odd there should be a difference in the output on pins 12-14 compared to pins 15-18 to ground, right?
I'm getting more confused so hope you can spot something I'm doing wrong.
