Posted this on old thread as well but thought it would be noticeable as a new thread so here it is:
Well, I'm back with more questions.
Starting from scratch, here is the scenario of what I would need to please the client. There are 3 locations in a public building that want a "panic" button to signal the sheriff's dispatcher
that officers are needed to intervene in a developing situation.
What is desired is that the momentary push of a button will yield a contact closure there and a wire pair runs from the switch all the way to the dispatch room on ground floor.
Here we want a display with 3 red indicators (one for each of the 3 locations monitored) and a buzzer/sounder to draw attention to the dispatcher. He would see from the
display which location requested the help and proceed to dispatch officers to the location. (also would like a suggestion on how to label the red indicators so it is clear yet
takes up minimum space.... sheriff is adamant about keeping this to least amount of "crap" and wires necessary... tough to please).
Rather than the dispatchers have to worry about and take time to reset or cancel the light and noise after handling the emergency, I think they would accept another option.
With the proper circuitry, the light and sound would only last for a pre-set time.... great if it could be field adjustable.... and then shut off. It should be long enough to notice
if they were not exactly at the desk but not so long to be irritating and interfering with ongoing processes.
It would be ideal to have the sound/buzzer be on for a certain number of seconds, then go off but with the red light (blinking) remain for a minute or two so an officer that
stepped away for a minute would still be able to see the light once the noise had caught his attention.
With the sheriff's request for minimum clutter & wiring in his area, to what extent could I locate these items near the origin of the signal and yet get required commands to
each light/buzzer. This setup would then be done the same for each of the 3 locations.
I don't know anything about it but a PLC (programmable logic controller) device was suggested but sounds to be a bit overkill when it is just a couple of logic and timer steps involved I would think.
Any help will be much appreciated!
http://www.automationdirect.com/adc...ors/22mm_Plastic/Audible_Buzzers/ECX2071-127R
Above link is example of what I have come across for the light/buzzer. Have to make a box or panel and insert and label these ... or something better.
izon, 37 minutes ago Edit Delete Report
