I have just received a small(12mmx22mm) motion sensor module which is all surface mount and has very small edge pads for interconnections. The module is reasonably expensive and for prototyping and just getting it going I would like to connect it up without soldering it down. My thinking is to make some small springy bent L edge connectors sort of like shown below and solder these on to a copper clad board as a breakout
Now I am no watch-maker, I have tried similar things in the past and whilst in my head they always look professional, the end result is usually a lash-up. So are there any other ideas of how to do this or any tips on forming tiny parts, it is all going to be hand made and hand soldered. Not all the pins I need to connect are on one edge and the big concern is accuracy of making and positioning the spring connector so that they both hold the board and make reliable contact.
Code:
_/................\_ ....... Module
------------------- ----- PCB
