Ideal vs practical op amp help
Discussion in 'Homework Help' started by joepdon, Jan 27, 2016.
  1. joepdon
    Jan 19, 2016
    10
    The lab I am working on is about ideal and practical op amps. We started off wiring up an ideal op amp for just one step and measured the output voltage before setting up the practical op amp. In the lab report I am suppose to discuss what I observed when doing this and explain why the ideal op amp integrator is not a practical circuit. It then says to note the amount of feedback that exists in the ideal integrator. Then it asks for the importance of adding a feedback resistor in parallel with the capacitor creating a practical ideal integrator.
    I know the difference between the ideal and practical, but I guess I just don't understand what I am looking at. The voltage output for the ideal was 11.5V and with adding the feedback resistor which is double the input resistor I saw 13.1mV. Can someone help me realize what went on. Keep in mind this is my second circuits class and I haven't taken a circuits and differential equation class for about a year so things might need to be broke down into baby steps.
    Thanks.
  2. WBahn
    Mar 31, 2012
    18,088
    4,917
    Where did you find an ideal op amp to wire up in a lab course?
    ErnieM likes this.
  3. joepdon
    Jan 19, 2016
    10
    I guess we do not have one we just use the lm741 and wire it up as seen in figure 1 and call it ideal? Cause there is no real life ideal op amp right?
  4. RBR1317
    Nov 13, 2010
    267
    54
    It is likely that the ideal/non-ideal label is not referring to the op-amp itself but rather to the circuit design which assumes what the op-amp that is used will be. So using a 741 in a circuit that was meant for an ideal op-amp can lead to some really bad performance results.
  5. joepdon
    Jan 19, 2016
    10
    I think that is what my professor is doing, which makes sense in showing that solving it with the assumptions of an ideal op amp on paper doesn't work in real life.
  6. WBahn
    Mar 31, 2012
    18,088
    4,917
    Under what conditions did you measure the output? It's an integrator, so you expect it's output to be a function of the history of its input.
  7. joepdon
    Jan 19, 2016
    10
    I measured the output with an oscilliscope connected to ground and the output. The op amp is biased at +/-12V, C=1nF, R1=100Kohms, R2=200kohms. Or are you asking for the equation?:
    Vout(t)=-(1/(RC)) integral[Vin(t)dt - Vc(0)] from 0 to t (this is for the ideal op amp)
  8. thumb2
    Member
    Oct 4, 2015
    92
    6
    Adding a feedback resistor the circuit turns into a inverting amplifier, so the output falls down to GND (0 V).
    Note that the second circuit is also a low-pass active filter. ;)
    joepdon likes this.
  9. hp1729
    Nov 23, 2015
    2,105
    235
    By Ideal versus Practical I take it you refer to one with just the cap as feedback versus one with a resistor?
    Were the voltages you refer to DC or AC, If AC what frequency?
  10. hp1729
    Nov 23, 2015
    2,105
    235
    < :) >Dang. Will we ever get away from that LM741 in schools? </ :) > It is still a good example of a bad example in op amps. The "Acme product" everybody wants to compare their product to for "lower offset ... less noise ... etc.
  11. joepdon
    Jan 19, 2016
    10
    In this part of the lab we measured them in DC.
  12. WBahn
    Mar 31, 2012
    18,088
    4,917
    So what was the DC input voltage? 0V? 10 V? What?
  13. dannyf
    Sep 13, 2015
    2,196
    417
    The ideal integrator is likely oscillating. The integration capacitor shorts the opamp to ground and most opamps, especially a 741, would not be able in that case.
    The ideal of paralleling the capacitor with a large resistor is to better define the upper end of the gain. However, in this case your choice of that resistor has too low of a value. Use a large value resistor instead.
  14. dannyf
    Sep 13, 2015
    2,196
    417
    BTW, when the circuit is working, its output will change linearly with time. Either increase or decrease depending on the flow of current.
  15. joepdon
    Jan 19, 2016
    10
    +/-12V
  16. dannyf
    Sep 13, 2015
    2,196
    417
    I would venture a guess that the input voltage is quite low, in the 13mv range.
  17. hp1729
    Nov 23, 2015
    2,105
    235
    The capacitor is an open circuit at DC. Maximum gain in the op amp and max voltage out. This the difference with the resistor across the cap.
