Ideal Voltmeter infintite resistance question
Discussion in 'General Electronics Chat' started by atomtm, Nov 5, 2012.
  1. atomtm
    Aug 13, 2012
    24
    Hello everyone!
    I was just reading chapter 8 - dc metering circuits and I was wondering what if you could actually get a voltmeter with infinite resistance , how would that suppose to work with no current flowing through it! How could a user get a measurement from it with no current producing a torque in the needle mechanism?
    Thank you in advance
  2. colinb
    Jun 15, 2011
    351
    35
    The "ideal" voltmeter does not exist.
    That's the difference between an ideal, theorical thing and any real implementation in practice: an actual realization of something theoretical will be non-ideal in one way or another. No exceptions.
  3. davebee
    Oct 22, 2008
    539
    46
    You can sort of do that with a nulling circuit. You set up a low impedance variable voltage of close to the same value as the voltage under test.
    Connect the low impedance voltage output to the voltage under test through a sensitive ammeter, then adjust your low impedance voltage until you null the meter, so it shows zero current flow.
    When the meter is nulled, then your low impedance source is the same voltage as the voltage under test, with no current being drawn from the voltage under test, and you can measure the low impedance voltage to get a value for the voltage under test.
    That technique was common many years ago, but nowadays, I would suspect that there are op-amps with such sensitive inputs that the current they draw is so close to zero that they do a better job at this than a mechanical nulling ammeter would.
    (edit - I should have read the article - nulling meters are discussed in that chapter)
  4. crutschow
    Mar 14, 2008
    13,488
    3,372
    Voltage can be also be measured by the electric field it produces, which can be measured without drawing current. For example, a MOSFET's operation is determined by the gate-source voltage which generates an electric field in the drain-source channel beneath the gate which controls the drain-source current. The gate looks like a capacitor, drawing only a minute DC leakage current, so it is a close approximation to the ideal.
  5. MrChips
    Oct 2, 2009
    12,625
    3,451
    Such an instrument is called an electrometer, i.e. it measures electric field while taking very little current.
  6. atomtm
    Aug 13, 2012
    24
    Thank you for your answers !!
    Cheers
  7. KMoffett
    Dec 19, 2007
    2,584
    234
