Ideal Voltage/Current Source
Discussion in 'General Electronics Chat' started by Rukhairil Aizat, Jan 14, 2015.
  1. Rukhairil Aizat
    Jan 14, 2015
    Hi guys, i have a little bit confuse between ideal voltage source and ideal current source?:( have a nice day :)
  2. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi,
    Look at this PDF for an explanation.
    E
    Rukhairil Aizat likes this.
  3. nDever
    Jan 13, 2011
    154
    Welcome,
    What about ideal sources is giving you trouble?
    Ideal voltage sources have no internal resistance, and if they are shorted, an infinite current is pulled. Of course, real voltage sources always have some amount of internal resistance; they pull a finite current if shorted (but you should never short any voltage source in practice). Ideal voltage sources also maintain a constant voltage no matter what is connected to them.
    Ideal current sources maintain a constant current through them no matter what is connected to them.
    Ideal sources are used in circuit design because they simplify circuit analysis. They are also useful because they can be used to model many components that would be difficult to analyze otherwise.
  4. crutschow
    Mar 14, 2008
    13,498
    3,374
    Unless the voltage source is designed with a current-limit to tolerate a short, such as most bench power supplies.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    The simplest way, IMO, to keep them straight is that an ideal voltage source will produce whatever current is needed, be it positive, negative, or zero, in order to maintain the specified voltage across its terminals. Similarly, an ideal current source will produce whatever voltage is needed, be it positive, negative, or zero, in order to maintain the specified current through its terminals.
    cabraham likes this.
