Ideal Transformer Question
Discussion in 'Homework Help' started by xz4chx, Sep 27, 2013.
  1. xz4chx
    Sep 17, 2012
    71
    So for part A, I have an ideal transformer connected to a couple resistors.
    *All voltages and currents I am assuming are rms in the problem because i don't want to type RMS for each one.*
    a) So I did a source transformation to make the current source into a voltage source.
    So V_{th}= 240<0 [mV]
    Since I did a source transformation:
     R_{th}=5+15=20 [k\Omega]
    So i know in order to get the max amount of power from the load I have to make the source see a 20 [kΩ] through the number of turns in the coils. I am not 100% on how to do that (Find N2)?
    b) That is just a voltage divider so I get  P= V^2/R
    P= (120)^2/20 = 720 [mW]
    c) The voltage before the inductors and load is 120 V so if i put V2 across N2 then I have V_1+V_2=120 [V] , also the voltage per turn is the same so but with dot convention they are opposites
     V_1/N1=-V_2/N2<br />
V_2=-(N2/N1)*V_1
    Putting that back into first equation
    V_1-(N2/N1)V_1 = 120 (Solve for V1 which will give me V2)
    d) Putting the circuit back to its original form before source transformation, I need to find the voltage across the source
    KVL gives me  V_{cs} = 120V + (240/40000)*5000 = 150 [V]
    (240 [V] /40000 [Ω]) [<-- current before transformation back]
    So  P_{cs} = 150 * 10^-3 = 2.4 [W]
     % = (.72/2.4)*(100)= 30%
    _________________________________________________________________
    So I just need to know how to find N2. I have been given a formula sheet which does not seem to help and we have not gone over this in class yet but my homework is due next tuesday and I am interested on how to solve for this.
    Thanks for the help and time
    Zach
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The winding voltages must be directly proportional to their individual number of turns as you have already indicated. What is the voltage V2? If you know a certain number of turns gives you voltage V1 (for which you have developed an equation) then a commensurate number of turns will give voltage V2.
