Find Vo in terms of V1 my attempt for writing node equation guide me plz ...
Are the two wires that cross in the upper middle connected, or do they just cross each other?-2/10k + v1/10k + vi/15k = - v1/10k
Why do you say that the upper left node is at -2 V?
Then, in your work, why do you only circle the vertical one since the horizontal one is the same node/It is connected in the upper middle ...
Whether it is a supernode or not is beside the point. You have indicated that the voltage of the upper left node is -2 V. Why? Just because it is connected to negative side of a -2 V supply?yes theres a voltage source between 2 non reference nodes its a supernode
Please check my node equation..i wasn't thinking of super node that time you made me think of that point ..your so much helpful I wish to be like you helping others.. thanks for your replies
If I check your node equations it will be to see if they are in agreement with your diagram. There's no point in doing that until your diagram is unambiguous.Please check my node equation..
No problem -- we'll get there and you will learn a bunch in the process.Please accept my sincere apologies for the mistake
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
