Ideal Op-Amp Question
Discussion in 'Homework Help' started by KillerZ123, Jan 30, 2011.
  1. KillerZ123
    Nov 25, 2010
    7
    I have an Op-amp that looks like this:
    and I am trying to derive this equation for Ix:
    I_{x} = (V_{s})\frac{R_{1}R_{3}}{R_{x}(R_{1}R_{3} - R_{2}R_{4}) + R_{1}R_{3}R_{4}}
    Here is what I have so far:
    V_{-} = (V_{o})\frac{R_{1}}{R{1} + R_{2}}
    V_{-} = V_{+}
    I1 going through R4 is:
    I_{1} = \frac{V_{s} - (V_{o})\frac{R_{1}}{R{1} + R_{2}}}{R_{4}}
    I2 going through R3 is:
    I_{2} = \frac{(V_{o})\frac{R_{1}}{R{1} + R_{2}} - V_{0}}{R_{3}}
    Then Ix is:
    I_{x} = I_{1} - I_{2}
    I am not sure if this is correct up to here?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    You are OK so far. There is a very good simplification to be done in the I2 current formula.
    Add the equation V+=Ix*Rx and you are good to go.
  3. KillerZ123
    Nov 25, 2010
    7
    OK I got it thanks for the help.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Glad to hear you solved it.
