Ideal op amp (current to voltage converter + inverting)
Discussion in 'Homework Help' started by naspek, Mar 20, 2010.
  1. naspek
    Feb 17, 2010
    45
    Hey there.. need helps here..
    The question is..
    Derive an expression relating the output voltage, Vo to the input current, Iin.
    i try to derive it.. but..
    got problem with RL
    V1 = -IinRf
    Vo =- R2/R1(-IinRf) how to include Rl in my derivation?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Voltage gain don't depends on the load resistance
    naspek likes this.
  3. naspek
    Feb 17, 2010
    45
    should i ignore the RL?
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    RL should be high enough in value to not overload the drive capability of the amplifier.
    naspek likes this.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, because you dealing with ideal opamp.
    naspek likes this.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    To reinforce the statement already provided by others, the load resistance normally does not have an effect on the gain. Particularly when you are dealing with an ideal opamp.
    hgmjr
    naspek likes this.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    An ideal op amp has zero output impedance.
    naspek likes this.
