(idea to reality) small buggy car to find a transmitting signal
Discussion in 'The Projects Forum' started by isakiwanuka, Jan 28, 2012.
  1. isakiwanuka
    Jan 28, 2012
    HELLO TO ALL READERS
    thank you first all for taking time to read.
    i have a project to do next year for my last year of electronics degree
    i want a head start as i have good equipment at home
    my idea is to build a buggy car with 3 wheels and 2 motors ..i want the car also to detect when it is next to walls and objects so it doesn't crush into them.
    i then want the buggy car to be able to find the transmitting signal which could be placed in a different room and the buggy car to find it .
    i know i will need to use sensors and motors and a transmitter and receiver
    i don't want to control the buggy car i just want it to find the transmitting signal.
    I WOULD LIKE TO KNOW WHAT PEOPLE THINK AND ANY IDEAS ON HOW I CAN MAKE THIS IDEA REAL ...EG SENSORS THAT I CAN USE , TRANSMITTER/ RECEIVER CIRCUITS OR OTHER WAYS THE BUGGY CAN FIND THE SIGNAL
    I WOULD APPRECIATE THE HELP
    THANK YOU FOR YOUR TIME
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    I would work on the buggy car not hitting walls portion before I get into wireless communications.
    Look into ultrasonic sensors and infrared sensors:
    http://www.parallax.com/tabid/768/ProductID/92/Default.aspx
    http://www.sparkfun.com/products/242
    Also, read this book cover to cover:
    http://www.amazon.com/Designing-Embedded-Systems-PIC-Microcontrollers/dp/0750667559
    It is 99% of what you want to build.
  3. isakiwanuka
    Jan 28, 2012
    thank you
    yu are right as i plane to build the buggy first den deal with it not been able to hit the wall
    i was wondering is der any other way besides wireless were i can get da bugy to find the transmitting signal by itself.
    and i will defo be buying dat book thank you
  4. PaulEE
    Member
    Dec 23, 2011
    423
    32
    The issue with a buggy finding a wireless signal (electromagnetic radiation) is that E-M radiation radiates in all directions (basically) from an antenna. Depending upon what frequency the radiation is, it could be made more directional or less, but in either case, it is complicated.
    Perhaps your buggy could seek out a lit candle or infrared LED radiation? You could program it to continue to look around until it sees a strong enough heat signature to satisfy the device.
    Alternatively, you could tell it to listen for an ultrasonic noise, such as a pulse. It could then follow the signal and know it's getting closer as the sound gets louder..?
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    My Off Topic comment about the poor English has been deleted.
  6. isakiwanuka
    Jan 28, 2012
    cheers for da advice
    i think i will look more into the ultrsonic pulse theory
  7. PaulEE
    Member
    Dec 23, 2011
    423
    32
