ID Inline fuse on a box fan
Discussion in 'General Electronics Chat' started by Gdrumm, Nov 20, 2009.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I'm working on a cheap Galaxy Box Fan that stopped working.
    I have found what I believe to be a small blown fuse, inline with one of the power feeds.
    I tried to find it on ALLDATASHEET, but came up blank.
    It looks to be ceramic, about 1/2" long with brownish gold lettering, and brownish gold tips on either end,. The info includes:
    <PS>E
    115 C 2A
    M N110
    069
    Continuity test was negative (no conductivity).
    Have I identified this correctly, is it a small fuse?
    Thanks,
    Gary
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It does sound as if it might be a 2 amp fuse. The question now is: why did it blow? If you have a meter, you might check by seeing what the resistance through the coils is. If it is 0, or very close, the motor may have gone bad.
    If you just want to see, go to a hardware store and find an inline fuse holder. Get a 2 amp 120 volt fuse to go in it, and put the fuseholder in with wire nuts. If that fuse blows, consider a new fan.
  3. Gdrumm
    Aug 29, 2008
    684
    36
    Thanks,
    I'll give it a try.
  4. Duane P Wetick
    Apr 23, 2009
    408
    19
    This might be one of those one-time circuit interrupters. It works like a fuse, except it is temperature dependent and not just current heating a wire dependence (fuse).
    The question then becomes, why did it clear? Stalled fan motor? Overtemp. area?
    Replacing with a slo-blo fuse of 2A. is a good fix.
    Regards, DPW [spent years making heaters out of op-amps.]
