Id current in 2n7000 Mosfet
Discussion in 'General Electronics Chat' started by ckhaos99, Feb 12, 2012.
  1. ckhaos99
    Feb 12, 2012
    I'm looking at the datasheet for a 2n7000 nmosfet transistor and I'm a little confused. Id max according to the datasheet is 200mA but when I look at the graphs it shows Id up 2A. I want to operate the fet with a higher Vgs around 15V and in the saturation region but if Id can't be higher than 200mA it doesn't seem possible. Any help would be great. Heres a link to the datasheet :http://www.google.com/url?sa=t&rct=...ms_-HJadAeykwxT-w&sig2=j2uHzCtbJghoioz3xp2jnA
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    The difference in the current is explained by the fact that the N-ch mosfet can only handle 200mA of continuous current. The device can withstand higher currents when they are applied in the form of a pulse of the specified duration and duty cycle.
    hgmjr
  3. Mr. Mho
    Member
    Jun 15, 2009
    15
    I agree with hgmjr and also add... don't forget to check max power too... big difference in power if VDS is 1 V or 10V...
  4. crutschow
    Mar 14, 2008
    13,515
    3,386
    Not so much if he's using it as a fast switch and turning it fully on with 15V.
