ID a couple components from a valve radio
Discussion in 'General Electronics Chat' started by bug13, Mar 2, 2015.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    Can someone tell me what are the two white cylinder thing on the right? And what are the cylinder thing with aluminum casing/shielding (between two valves) on the left?
    Thanks a lot guys!
  2. debe
    Sep 21, 2010
    955
    185
    2 objects on the right are wire wound resistors with adjustable taps. Shielded can is a IF transformer.
    bug13 likes this.
  3. bug13
    Feb 13, 2012
    1,213
    38
    Oh, and I forgot to ask, what are those four holes on the lower left? They are labeled as A, T, PU and M?
  4. debe
    Sep 21, 2010
    955
    185
    A is usualy for external aerial. PU is pickup (record player) don't know what T or M are.
    bug13 likes this.
  5. Dodgydave
    Jun 22, 2012
    5,150
    769
    T is "Earth" M may be microphone, PU record player, A aerial, looks like there is a dipole loop aerial around the case.
    on the right as previously said Resistors, and IF can shields.
    what's the model number?
    bug13 likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    bug13 likes this.
  7. bug13
    Feb 13, 2012
    1,213
    38
  8. bug13
    Feb 13, 2012
    1,213
    38
