Hello all.
I'm working on adding a 1v per octave CV in point for the ICL8038 chip. Right now, I have built the schematic below and it works as it should but obviously all I can do is sweep the a pot to change the pitch. I have just acquired a keyboard with CV outputs for pitch + key follow, and gate. I since have messed around with trying to get the two to talk and play nice but I'm not getting great results. I found I needed an additional trimmer to calibrate the oscillator (which is pretty neat because I can set it to change pitch a little as a cent up to whatever) across the keyboard. Now that being said, it works but the keyboard plays in reverse and I have tried to reverse the wires and then it doesn't play at all.
So I guess my question is: Where is the best patch points for what I want to do on the schematic? Also, do I need say, a VCA or (?) in front of the oscillator? I've made many "drone" machines but now I'd like to give them all a CV in to play them off a keyboard. Hope I've made sense.
Thanks in advance!
Thanks in advance!
