Ok, pin 6 and 7 are outputs. 6 is labeled OC and 7 is labeled OD. So what does this lead me to?
The answer is "The circuit counts upward" until counter reach 0011 and then he will "count down" to reach 0010, and then again count up to 0011 and down to 0010. So for 0.8V at the input,the counter output will be switch between 0010 and 0011 for every clock pulse.I'm not following. The answer to the question is what? How does the R/2R network work?
by Jake Hertz
by Duane Benson
by Jake Hertz
by Duane Benson
