Basically i did a program to read datas from this 3 axis accelerometer.
however the results is 0xff for all 3 axis. May i know what might be the possible cause?
Here is the code:
Here is the code:
Rich (BB code):
#include <DS89C4XX.h> //DS89C450 Microcontroller
#include <intrins.h> //_nop_() function
#include <stdio.h> //sprintf() function
#define _Nop() _nop_()
/*#define OUT_X_MSB 0x01
#define OUT_X_LSB 0x02
#define OUT_Y_MSB 0x03
#define OUT_Y_LSB 0x04
#define OUT_Z_MSB 0x05
#define OUT_Z_LSB 0x06 */
#define WHO_AM_I 0x0D
//#define SLA 0x1C //slave address
sbit SDA=P1^0;
sbit SCL=P1^1;
//i2c buffer
void I2CBitDly()
// wait approximately 4.7uS
{ // tune to xtal. This works at 11.0592MHz
unsigned int time_end = 10;
unsigned int index;
for (index = 0; index < time_end; index++);
return;
//i2c START
void I2CSendStart()
SDA = 1; // i2c start bit sequence
I2CBitDly();
SCL = 1;
I2CBitDly();
SDA = 0;
I2CBitDly();
SCL = 0;
I2CBitDly();
//i2c Stop
void I2CSendStop()
SDA = 0; // i2c stop bit sequence
I2CBitDly();
SCL = 1;
I2CBitDly();
SDA = 1;
I2CBitDly();
// Set SCL high, and wait for it to go high
void I2CSCLHigh(void)
register int err;
SCL = 1;
while (! SCL)
err++;
if (!err)
return;
//Send function
void I2CSendByte(unsigned char bt)
register unsigned char i;
for (i=0; i<8; i++)
if (bt & 0x80) SDA = 1; // Send each bit, MSB first changed 0x80 to 0x01
else SDA = 0;
I2CSCLHigh();
I2CBitDly();
SCL = 0;
I2CBitDly();
bt = bt << 1;
SDA = 1; // Check for ACK
I2CBitDly();
I2CSCLHigh();
I2CBitDly();
if (SDA)
SCL = 0;
I2CBitDly();
SDA = 1; // end transmission
SCL = 1;
// Transmit to SDA
void I2CSendAddr(unsigned char addr, unsigned char rd)
I2CSendStart();
I2CSendByte(addr+rd); // send address byte
// Receive from SDA
unsigned char I2CGetByte(unsigned char lastone) // last one == 1 for last byte; 0 for any other byte
register unsigned char i, res;
res = 0;
for (i=0;i<8;i++) // Each bit at a time, MSB first
I2CSCLHigh();
I2CBitDly();
res *= 2;
if (SDA) res++;
SCL = 0;
I2CBitDly();
SDA = lastone; // Send ACK according to 'lastone'
I2CSCLHigh();
I2CBitDly();
SCL = 0;
SCL=1;
I2CBitDly();
return(res);
//delay
void delay(int count)
int i,j;
for (i=0;i<count;i++){
for (j=0;j<1200;j++); }
///////////////////////////////////////////SERIAL PORT/////////////////////////////////////////////////
void Tx(unsigned char c)
while (TI_0==0);
TI_0=0;
SBUF0=c;
//////////////////////////////////////////Digital Transfer//////////////////////////////////////////////
void Tx_char(unsigned char c)
unsigned char s[4];
int i;
c=c&0xff;
sprintf(s,"%#x",(int)c); // write into string.
for (i=0;i<4;i++) Tx(s);
//////////////////////////////////////////String port////////////////////////////////////////////////////
void Uart_Tx2(unsigned char x)
while (TI_0==0);
TI_0=0;
SBUF0=x;
////////////////////////////////////////////Send String//////////////////////////////////////////
void sendstring (char *String)
int i=0; //set counter to 0
while(String)
Uart_Tx2(String[i++]);
void main ()
unsigned char value;
SCON1 = 0x52;
SCON0 = 0x52;
TMOD = 0x20;
TCON = 0x69;
TH1 = 0xFD;
delay(500);
sendstring("System boot...");
while(1)
//READ X_MSB
//sendstring(" ");
sendstring(" XMSB: ");
delay(500);
I2CSendAddr(0x1C,0x38);
I2CSendByte(0x01);
I2CSendAddr(0x1C,0x39);
value = I2CGetByte(1);
Tx_char(value);
I2CSendStop();
delay(1000);
sendstring(" XLSB: ");
delay(500);
I2CSendByte(0x02);
Tx_char(value);
I2CSendStop();
delay(1000);
sendstring(" YMSB: ");
delay(500);
I2CSendByte(0x03);
Tx_char(value);
I2CSendStop();
delay(1000);
sendstring(" YLSB: ");
delay(500);
I2CSendByte(0x04);
Tx_char(value);
I2CSendStop();
delay(1000);
sendstring(" ZMSB: ");
delay(500);
I2CSendByte(0x05);
Tx_char(value);
I2CSendStop();
delay(1000);
sendstring(" ZLSB: ");
delay(500);
I2CSendByte(0x06);
Tx_char(value);
I2CSendStop();
delay(1000);
