IC Timer Expert Help
Discussion in 'General Electronics Chat' started by dociledragons, Oct 6, 2013.
  1. dociledragons
    Oct 6, 2013
    8
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
    Depends how its configured, could be by disabling the set pin1,reset pin 2 or osc inhibit pin 14,
  3. dociledragons
    Oct 6, 2013
    8
    Would it help if I took a pic? I disabled pin 1. Now I wait.
  4. Dodgydave
    Jun 22, 2012
    5,142
    768
    yes take piccys and post
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
  6. Alec_t
    Sep 17, 2013
    5,968
    1,135
    I haven't studied the datasheet in depth, but would disabling any of those pins actually cause the IC to shut off? That's the opposite of what is wanted.
    Edit: Ok, after checking the sheet further it seems holding pin 1 high and pins 2,7,14 low will cause the output (pin 13) to stay high (=on).
  7. dociledragons
    Oct 6, 2013
    8
    OK thanks for the reply everybody.
    Sadly, I shorted out the circuit. Ops... So, now I'm in need of curcuit that that can power the heating element safely.. Would it be as easy as a Potentiometer, a couple resistors, diode??? Except I have three wires coming out the heating pad. I can assume the third one is the thermometer.
    Any help would be appreciate. I no I could purchase a light dimmer but those are 10 plus bucks. If I were to do that I would just purchase another heating pad.
    Edit: I just need it on a "High" setting.
  8. Alec_t
    Sep 17, 2013
    5,968
    1,135
    It might not be safe to ignore the thermometer wire. The pad could overheat if powered uncontrolled. Depends on the design/spec (unknown).
