What is some good IC chips that have a large library for every TTL, CMOS, Op amps . etc. to test IC chips in circuit and out of circuit?
The Huntron doesn't have any library or compare to a known good IC chip. So I need to buy some IC testers to be able to have a library to compare to for troubleshooting circuit boards.
I use the Hutron to check the signatures of IC chips in circuit but I need an IC tester to test TTL, CMOS, Op amps etc to know if the IC chips are good or not.
