IC SN74LS04 gives only 4.2 V on output. Is it normal?
Discussion in 'General Electronics Chat' started by Radik, Oct 4, 2015.
  1. Radik
    Oct 4, 2015
    I apply 5V as power supply to the VCC pin (14).
    According to the data sheet I grounded all unused inputs.
    When I apply 5V to the input pin I get 0.16V on output.
    When I apply 0V to the input pin I get 4.2V on output.
    I would expect to have 5V on output when I apply 0V.
    In datasheet there is only output amperage specified. What is about output voltage?
    best regards,
    Radik
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Radik likes this.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The TTL Totem pole output stage does not behave like a CMOS output stage. If you look carefully at the TTL internal schematic you will see an internal pullup resistor that current must flow through. The more current the gate sources, the greater the voltage drop. That is why the minimum output voltage high is 3.5 volts and the minimum input voltage high is 2.0 volts. There has to be some margin.
  4. Bordodynov
    May 20, 2015
    670
    194
    Output high level in the chip makes the transistor type Darlington. These are two of the transistor and the resistor. No-load output voltage equal to Vcc-0.8V (Vbe ~ 0.8V). With an average load VH ~ Vcc-1.6V.
