IC relay?
Discussion in 'The Projects Forum' started by rubicon99, Apr 30, 2012.
  1. rubicon99
    Apr 19, 2012
    46
    Are there any IC chips that have relays in them? Rather not a solid state relay. I just want to amplify voltage with a switch on or off in an ic chip.
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    Google: DIP relay
    These are relays that are packaged in DIP packages like ICs, and can be pluged into DIP sockets.
    Ken
  3. rubicon99
    Apr 19, 2012
    46
    Actually I guess solid state relays are fine
  4. KMoffett
    Dec 19, 2007
    2,586
    234
    What are you trying to do? Can you post a schematic?
    Ken
  5. mcgyvr
    Oct 15, 2009
    4,793
    976
    A transistor..
  6. rubicon99
    Apr 19, 2012
    46
    I found this... pretty much making an estop system with a microcontoller that will give a ttl signal and amplify it to 12-24 volts if I give a high, or give 0 volts if I give a logic low. I attached a schematic, but I need to change it and get rid of the ULN2003 cause since I am pulling high a load to ground will change the voltage.
    I found this... Can I use it, it says solidstate relay but its using mosfets to do switching. Do yall think it will work for my application?
    http://www.vishay.com/docs/83804/lh1500aa.pdf
  7. KMoffett
    Dec 19, 2007
    2,586
    234
    What's the current in the 12-24V e-stop circuit?
    Ken
  8. rubicon99
    Apr 19, 2012
    46
    max 200 MA... more like 100 MA
  9. KMoffett
    Dec 19, 2007
    2,586
    234
    That would be pushing that SSR, since it's only rated at 150mA.
    Ken
  10. rubicon99
    Apr 19, 2012
    46
    In that datasheet, would you input the ttl signal to the LED? Have ground on the S' pin and output on the S pin?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The solid state relay has an Rds(on) of 20 Ohms. That means when it is conducting, it's resistance will be 20 Ohms.
    For 200mA to be flowing from a 24v supply requires a 120 Ohm resistance. So, assuming your load is 120 Ohms, and the solid state relay has a resistance of 20 Ohms when it's on, your actual current will be about 171mA, and your load will have about 20.6v across it; 3.4v across the SS relay. You probably won't like that.
    It would have helped if you had mentioned your load current prior to now.
    More on SSR's; keep in mind that many of them use Triacs or SCRs internally, which will not turn off if you are using DC.
  12. KMoffett
    Dec 19, 2007
    2,586
    234
    Yes...but...the Ron is ~20Ω. At 200mA that's a voltahe drop of 4 volts across the "contacts" and a power dissipation of 800mW. The absolute maximum continuous Pdiss is 550mW.
    Ken
  13. rubicon99
    Apr 19, 2012
    46
    Damn a 4 volt, voltage drop. Are there any solid state relays where I won't have a voltage drop. I don't think there is a voltage drop in elctromagnetic relays.
  14. rubicon99
    Apr 19, 2012
    46
    So prob not a good idea to use a solid state relay for my application. Any suggestons where I can amplify voltage if I swithed the state on my microcontoller or turned it off.
  15. mcgyvr
    Oct 15, 2009
    4,793
    976
    Its VERY common in the micro world to simply use a digital output pin feeding a transistor..feeding a relay to switch high voltage/current loads..
    With this setup a 5V high or 0V low can be used to switch very large devices on and off from a micro output..
    Even just a transistor can be used for smaller (but more than the micro pin can supply) loads
    Just like this
    http://www.arduino.cc/playground/uploads/Main/relays.pdf
  16. rubicon99
    Apr 19, 2012
    46
  17. KMoffett
    Dec 19, 2007
    2,586
    234
    Your schematic doesn't show anything about the 12-24V circuit. Can you post that?
    Ken
  18. rubicon99
    Apr 19, 2012
    46
    Its the input voltage. Depending on the input voltage that is given. In the previous schematic you have a 12-24 volt input that I would feed into the ULN2003 and now I guess I would do that with the solid state relay. The output would just have a load from 1k - 10K.
  19. KMoffett
    Dec 19, 2007
    2,586
    234
    Looks like the same schematic. Are you saying that the 12-24V is Vcc on the schematic, and you need a high-side switch to turn that on and off with a logic output from the uC?
    Ken
  20. rubicon99
    Apr 19, 2012
    46
    Yes, the 12-124 is just VDD, the input voltage, Yes I just need a high side swtch. The reason why the schmatic doesn't work is if I attaced a load going to ground from the output (ULN 2003 output after the pull ups) it will act like a voltage divider and I need the output voltage to be as high as the input if it is turned on.
