1. chrischristian
    Thread Starter Active Member
    Feb 22, 2008
    43
    I want to start with PIC programing and I have IC PROG freeware but, when I try to open the .exe file it shows error message
    " index 0 out of range in function TprogList.Getprogrammer"
    and when I give O.K. to error another error pop up
    "access violation at address 0047B71B in module 'IC PROG.EXE'.Read of address 0000000"
    what is it all about? :confused: ( I have downloaded system file (driver) too, and both (.exe and driver) are in same directory)
  2. chrischristian
    Feb 22, 2008
    43
    Ignore the above post as I my self solved it, the problem was that IC prog does'nt install driver automaticaly untill you select it from the option menu.:eek:, So if any one who have just started with IC prog this may help!
