IC packages
Discussion in 'General Electronics Chat' started by shreyas_bhat, Aug 6, 2005.
  1. shreyas_bhat
    Thread Starter Active Member
    Jul 26, 2004
    47
    Does anybody have a clue wat the "BSC", in the dimension specification for Small Outline packages for ICs actually means.
    I need the dimensions of the spacing between two pins in a SOT 23-5 package IC. However, the dimensions are expressed in "0.55 BSC" etc. Therefore, umless I figure out what BSC is, I'm stuck at square one. My efforts on Google, so far have returned futile results.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It took some time to find it but in the end here is what I found.
    BSC definition
    hgmjr
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The spacing between the two pins on SOT23 is 1.9mm.
