IC Logic Problem
Discussion in 'The Projects Forum' started by earlspotswood, Mar 1, 2012.
  1. earlspotswood
    Mar 1, 2012
    Two inputs A and B. Two outputs, C and D.
    The idea would be to energize EITHER C or D depending on the order that A AND B were energized.
    For example if input A then B were energized, only C would then energize. If B then A were energized, then D would energize instead.
    I can use and, nand, or, nor, flip flops etc. but not whole microcontrollers. Please help?!
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Sounds like you need a state machine. Start by charting the states and outputs.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    You need to define better where the signals come from. Are they momentary or not, from switches etc. The power supply voltage of the circuit etc.
    The following circuit shows how it CAN be done, however you need to add something to reset the circuit. It is intended to work with momentary switches:
      File size:
      36.8 KB
      48
  4. earlspotswood
    Mar 1, 2012
    Wow, thanks a lot! That looks like it will do the job nicely. I'll be powering the circuit and sending the outputs to a PLC, so I think resetting it shouldn't be a problem.
  5. praondevou
    Jul 9, 2011
    2,936
    489
    If you use switches for the inputs you may need to debounce them... The circuit will only reset at power off, with the switches open.
  6. JDT
    Feb 12, 2009
    658
    85
    My first thought is: why don't you get the PLC to do it.
    Second thought: The above circuit seems overly complicated to me. Basically a single D-type flip-flop will do it. In the attached circuit I have added some gates so that the EITHER requirement is met and the not until both inputs are on.
    Have I missed something?
  7. praondevou
    Jul 9, 2011
    2,936
    489
    The other circuit is intended to work with momentary input pulses.
    Yours need the inputs to remain ON. (we don't know what the OP wants)
    Both circuits use two ICs.;)
  8. Motardo
    Sep 21, 2011
    20
    The propagation delay of the 7474 is 40 ns worst case, while the AND gates are only 3-6 ns each. So, you might get a short noise spike on the inactive output until the flip flop catches up with the ANDs.
