From the Lafayette Catalog N0. 670, 1966, I got this information:
The only IC's for sale were Texas Instruments "Solid State Networks" (also
called Integrated Circuits).
Series 53 Digital Modified - DTL (-55 degC to +125 degC)
(14 parts listed).
Series 73 Digital (Industrial) = Modified DTL (0 degC to +70 degC)
(13 parts listed that are slightly different than 53 series).
Series 51 Low-power Digital - RCTL (-55 degC to +125 degC)
(17 parts listed).
Series 15930 High-speed Digital - DTL (-55 degC to +125 degC)
(11 parts listed).
Series 15830 and Series 15830P High-speed Digital - DTL (0 degC to +70 degC)
(10 parts listed that are slightly different than 15 930 series).
Series 74 930 High-speed Digital - TTL (0 degC to +70 degC)
(Only 7 parts listed).
Series 54 930 High-speed Digital - TTL (-55 degC to +125 degC)
(Same 7 parts as the 74 930 series).
Series 52 Differential/Operational Amplifiers (-55 degC to +125 degC)
(7 parts listed. These ranged from $29.95 to $57.00 each).
Series 55 High-frequency Amplifiers (-55 degC to +125 degC)
(3 parts listed. $13 for video amps and $56.00 for a Magnetic-core Sense
Amplifier).
Series 74 and Series 74P High-speed Digital - TTL (0 degC to +70 degC)
SN7400, 10, 20, 30, 40, 50, 51, 53, 60, 70, 74, 7480, 90N and 91.
(Note the missing SN7404. A 7400 cost $6.50 and a 7474 cost $11.40).
Series 54 High-speed Digital - TTL (-55 degC to +125 degC)
(Same parts as the 74 series except there is no 7490N). A SN54 series part
cost exactly twice a SN74 series part).
In the 1971 Newark catalog, the SN7400 was $1.56 and the SN7474 was $3.11.
The MC1741 (uA741 equivalent) was as low as $2.10 each.
From Wikipedia: "Sourced by many manufacturers, and in multiple similar
products, an example of a bipolar transistor operational amplifier is
the 741 integrated circuit designed by Dave Fullagar at Fairchild
Semiconductor after Bob Widlar's LM301 integrated circuit design."
This paper has great detailed descriptions of early op-amps and some
interesting history:
http://web.stanford.edu/class/archive/ee/ee214/ee214.1032/Handouts/ho18opamp.pdf
From the above paper:
"The spectacular success of the 709 was associated with production
demands high enough to cause rapid and steep price reductions (despite
yields that were simply terrible for mysterious reasons). This op-amp,
introduced at approximately $70, was the first to break through the $10
barrier (and, later, the $5 barrier), guaranteeing extremely widespread
use. It is also the first op-amp used (and destroyed) by the author. By
1969, op-amps were selling for around $2."
(14 parts listed).
(17 parts listed).
(11 parts listed).
Amplifier).
