IC, Help
Discussion in 'The Projects Forum' started by micro, May 26, 2006.
  1. micro
    Feb 10, 2006
    26
    Hi! Recently I just get an M42SP-7, Stepping Motors from my old printer and I plan to use this motor. I have search an H-bridge IC which is Allegro, A3980. Can I use this H-bridge ic to contol my bipolar Stepper motor? Do you have this H-bridge application sheet (how to connect its pin) if this H-bridge is suitable for my case? Thank you first your kind help. :)
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    An H-Bridge is typically used to control a simple DC motor, not a stepping motor. The stepping motor requires synchronised pulses from a controller.
    Doug Jones explains better than I can: http://www.cs.uiowa.edu/~jones/step/
