IC for video amplifier and filter
Discussion in 'The Projects Forum' started by roboticvn, Jul 9, 2014.
  1. roboticvn
    Jul 9, 2014
    47
    I am making a transmit video signal circuit. I need an IC to amplify and filter the video signal. Can you show me ic how best to do this job. Thank you ^^
  2. crutschow
    Mar 14, 2008
    13,473
    3,361
    What type of video signal and over what medium do you want to transfer it?
  3. roboticvn
    Jul 9, 2014
    47
    I want to transmit composite video signal (NTSC) which uses 3.58MHz sub-carrier frequency. The signal after amplification is taken into pulse width modulation. Can you tell me what the best IC for this work? Thank you^^
  4. BeerBelly
    Dec 16, 2013
    29
    5
    What frequency would the pulses be. I expect the PWM would need to be 20 mhz or more.
    40 mhz would be better.
  5. roboticvn
    Jul 9, 2014
    47
    Frequency of pulses is 15MHz. What IC I should use?
  6. MrChips
    Oct 2, 2009
    12,623
    3,451
    I cannot see how you are going to succeed in transmitting a 40MHz video signal with a 15MHz PWM signal.
  7. roboticvn
    Jul 9, 2014
    47
    No, I want to transmit composite video signal (NTSC). The linear ramp carrier signal at a frequency of 15 MHz
    It here http://forum.allaboutcircuits.com/attachment.php?attachmentid=70600&stc=1&d=1404996227. I get it on the Internet but it doesn't have hardware information. Can you help me? Addition, can you tell me how does filter work? Thank you^^
  8. MrChips
    Oct 2, 2009
    12,623
    3,451
    I can't help you because I don't think it will work.
  9. DickCappels
    Aug 21, 2008
    2,753
    665
    You can firs try this without the filter or the amplifier, and if you test with a test pattern that does not change with time, you can connect the video to a DC restore (AKA clamp) circuit to the comparator. You will need a pretty fast sawtooth; I suggest 4x subcarrier otherwise you will get terrible beats between the sampling sawtooth and the subcarrier. Use a fast comparitor like the LM710.
    Later you can add a 4.5 MHz low-pass filter to the input.
    The circuit below includes an clamp and an 3.5 x amplifier. Adjust R29 to change the gain.
    [​IMG].
  10. roboticvn
    Jul 9, 2014
    47
  11. Dodgydave
    Jun 22, 2012
    5,139
    767
    It does mention some ics for video and audio, TVL3502 op amp, Si1563 mosfet, AK5386 ADC,
    its using optical transmission of video and audio using a pwm carrier of 15Mhz at a distance of 50 to 100 cm.
  12. roboticvn
    Jul 9, 2014
    47
    TVL3502 is used as a comparator. AK5386 is a ADC. I need a IC for amplifier and filter video signal. This isn't mentioned in journey.
  13. Dodgydave
    Jun 22, 2012
    5,139
    767
    well have a search for Ntsc video amps, check out this from LT
  14. BeerBelly
    Dec 16, 2013
    29
    5
    Another video amp with filtering you may try OPA360.
    Part and data sheet is at Mouser.com
  15. roboticvn
    Jul 9, 2014
    47
    Thank you everyone's help^^
